Welcome to Rocky Mountain Solo FORUMS General Autocross Discussion Run/Work Order for Event #3 MAKEUP 09/22/18
Viewing 3 posts - 1 through 3 (of 3 total)
  • Jon KuoJon Kuo
    **Run order changed.  AS moved to heat 2 and STS moved to heat 1
    Run Order
    BS CS ES GS HS SSC STR STS ESP FSP SSM JA JB CAMC CAMT CAMS
    SS AS DS FS STH STX STU SSP XP SM SMF FM X W
    Work Order
    • This topic was modified 6 years, 7 months ago by Jon KuoJon Kuo.
    Jeffrey TattershallJeffrey Tattershall
    Hi Jon, I put in the special comments on motorsportsreg that the yellow CRX will be running STS and X, but I guess the message didn’t come through!
    23 STS, 123 STS, 17 X, and 123 X (we will figure out numbers for X at checkin tomorrow) are all in the same heat right now. Can we move X or STS? Thanks!
    Sorry, I get a lot of requests and I mis read your’s. I read it as STX because it has STS then CRX right after, so I blended them and I missed that you wanted them separate. I don’t think it will change much if move STS to 1st heat. I’ll have to look after work since I don’t have the timing laptop with me.
    On a side note.  I try to accommodate all requests but sometimes I can’t.
