Viewing 4 posts - 1 through 4 (of 4 total)
  • Patrick SullivanPatrick Sullivan
    My 89 Fox Body
    sits on 195x75x14 – radials – “According to tire rack” the section width is 7.7″ tread width is slightly less. The question is
    do we use section width or tread width? when using the 1″ rule on tire size up-grade. Or am I drinking my bath water again?
    w/r
    Patrick Sullivan –
    I hope I posted in the correct area for this question?  Another Rookie!?
    The one inch rule is in regards to the diameter of the wheel. You can run 13,14 or 15 inch and any width you want as long as it fits the stock width wheel.
    Matt LeicesterMatt Leicester
    And if you run CAM, there are no limits!  But the rule for the Street classes is indeed the stock wheel diameter +/- 1 inch, stock width, and stock offset +/- 7 mm.  Any tire that fits a legal wheel is fine as long as the treadwear rating is 200 or higher.
    Thank You
    Chelsea Tattershall & Matt Leicester, that help’s a great deal, most kind.
    w/r
    Patrick Sullivan
