Welcome to Rocky Mountain Solo › FORUMS › Off Topic › Question about forum
AuthorPosts
If there is a FAQ about this forum, I apologize – I could not find it. So, I am just going to ask my question here: how to edit posts? It is usually quite obvious, but I wasn’t able to figure out how to edit my posts once they are posted. Could that functionality be disabled for me?
Thanks!
KamenOh, now I can see I am able to edit this post, but not others. Could it be that posts in certain forums cannot be edited? If so – which ones?
Kamen
Hi Kamen, you should be able to edit your own posts, but not the posts of others. If you let me know where (which forums or posts) you are seeing a discrepancy, and if you are able to provide screenshots, I would be happy to look into it further.
Hi, Ann,
Thank you for responding to my question! I have never tried to edit anybody else’s posting, but I certainly was not able to edit my first two posts in the “General autocross discussion” forum. Strangely enough, when I made the post above, I could see the “Edit” button on it – but not on my other posts – so I assumed it may have been forum-specific. However, now I don’t see an “edit” button even on this post here, so it seems to be a different kind of issue. I am attaching a screen-capture of my page view so you could see what I see. I don’t remember what I was seeing the other day when I was able to edit the post, but I but I believe there was an “Edit” button right by the “REPLY” and post number links; now you can see there is no such button, or any other obvious way to edit my messages. I hope this helps in identifying the problem. Thank you for your support!
Kamen
You must be logged in to view attached files.The same thing is happening again: I can edit the post I just made, but not any of the older ones. Could it be that the board only allows editing until somebody else posts, or after a certain amount of time? See the “Edit” button on my recent post.
Kamen
You must be logged in to view attached files.…and now the edit button (from the capture above) is gone! There seems to be a timeout, like a time window within which one can edit their posts, after which they become read-only.
Not that it’s a big issue, but in a couple of dozens of years of using forums, this is one of a handful I see do that, and the only one where it seems it is not by design.
Kamen
AuthorPosts
- You must be logged in to reply to this topic.
