Welcome to Rocky Mountain Solo FORUMS Announcements New RMSolo Class – Open Street Touring
Viewing 1 post (of 1 total)
  • Brian KellyBrian Kelly
    NEW LOCAL CLASS ALERT!!!! OST
    ~Open modifications & 200tw tires.
    Introducing a new RMSolo class, Open Street Touring! OST is the perfect place for drivers from other clubs to experience RMSolo events, while not having to be immediately concerned about conforming to standard SCCA classing.
    ~This is a true “run-what-you-brung” class for street cars with minimal rules encouraging maximum creativity and will have a PAX of .853! Sign up today!
    Below are the only rules for eligibility.
    -Only DOT approved tires with a treadwear rating of 200 or greater
    -Only production vehicles (or those based on production vehicles) are eligible. (No Exocets or similar. Something bought at a dealership)
    -All body panels must be present, but may be modified or replaced
    -All vehicles must pass a standard technical inspection compliant to that of the SCCA rulebook. A non exhaustive list of requirements for reference:
    -No high rollover risk vehicles such as SUVs, minivans, and trucks. The ratio of vehicle height to track width must be 1:1 or less
    -Factory seat belts or securely mounted replacements (3 point or more) must be present and used
    -No loose items in the vehicle. All cameras must be securely mounted.
    -Batteries must be securely mounted
    -All lug nuts must be present
    -No cords showing on any of the tires
    -No excessive fluid leaks
    -Wheel bearings must be in good condition
    -No meth/alcohol injection
    -No NOS
