Free to a good home, (but if you twist my arm, I’ll take beer)
This stuff is off a 1994 1.8L Miata
NA engine under tray with grill insert
Complete cylinder head 1.8L, 110K miles, ran great when removed (replaced with a 2001 head)
Intake manifold
Exhaust Manifold and mid pipe
ignition coils & plug wires
crank angle sensor (CAS)
throttle body w/TPS (no ICV)
MAF sensor
complete air-box & crossover tube
charcoal canister & purge control valve
used pistons, stock size, 110k miles
front control arms and uprights
94 ABS system
94 master cylinder and booster
NA 1.8 front brake calipers
’94 power mirrors with all wiring
lots of small bits
2001 VTCS intake manifold
‘99 steering rack with a welded the pinion shaft (de-powered).
’01 rear sport calipers
’99 power steering pump
hard top latches
oem seals that will fit aftermarket hard top
Bring a truck,
Located between Arvada & Golden, Near I-70
we can maintain good social distancing throughout the process!
reply with a post & PM
This topic was modified 4 years, 11 months ago by
Graeme D. Reason: add photo
You must be
logged in to view attached files.
