Welcome to Rocky Mountain Solo FORUMS Event Details May 1 – Championship Series #1 – (PPIR Infield)
Viewing 12 posts - 1 through 12 (of 12 total)
  • Iain MannixIain Mannix
    Greetings all – the 2022 RMSS officially gets underway this coming Sunday, May 1st, 2022.
    For starters, the course map is attached.
    Please sign the e-waiver to speed up registration/check in – you’ll still have to sign PPIR’s physical waiver at the gate, but the SCCA waiver/release of liability can be signed electronically.
    Map attached, see you Sunday!
    <span style=”text-decoration: underline;”>Specialty Jobs</span>
    Gate:
    6:30 – 8:
    8- 9:30:
    Setup:
    1) Reuben Brown
    2) Bud Smith
    3) Arnie Coleman
    4) Terry Brown
    5) mike Cahill
    Tear Down:
    1)
    Reuben BrownReuben Brown
    Ill help setup
    Reuben Brown
    95 XA
    Chelsea,
    Grid if I don’t get tapped for SSS.
    Tom
    Mike DunettsMike Dunetts
    Safety, or tech, or grid, or whatever else you need.  Thx!
    Terry BrownTerry Brown
    Setup
    Terry Brown
    91 CAMT
    Jeff HumphreyJeff Humphrey
    Available SSS
    Mike Dunetts – CAMC
    Tom Johnston – CAMC
    Randy Hickman – AS
    Aaron Botnick – AS
    Jeff Hugo – X
    Hap Schadler – CAMT
    Glen OutcaltGlen Outcalt
    Run 1 / Work 2
    SS BS DS SSC STR STU CAMC CAMT CAMS
    Run 2 / Work 1
    AS CS ES FS GS HS HCS STH STX X S PM XA XB
    Trailer work assignments
    Computer: Jeanette Wicks
    Radio: Sam Sheehan
    Log: David Gladu
    Scanner:
    Announcer:
    Supervisor: Jonathon Kuo
    <p style=”text-align: left;”>Heat 2
    Computer: John Feustal
    Radio: Michael Mai
    Log: Kelly Ann Gladu
    Scanner: Matt Villescas
    Announcer: Van Townsend
    Audit: Andrea Mai
    Supervisor: Danielle Sheehan</p>
    Final Audit: Melanie Dorsey
    Heat 1 Safety
    Aaron Botnick
    Randy Hickman
    Heat 2 Safety
    Hap Schadler
    Tom Johnston
    Mike CahillMike Cahill
    Setup please
    40 CAM-C
    Robert StanleyRobert Stanley
    Grid Sheets!
    John CollinsJohn Collins
    Chelsea
    Scanner or grid assistant please
    96 HS
    Thanks
    John
    Chris GladuChris Gladu
    Tech:
    Early tech:
    Cassidy Coghlin
    Jeffrey Tattershal
    During 1st heat
    Steven Clark
    Chris Gladu
