Viewing 4 posts - 1 through 4 (of 4 total)
  • Paul HarterPaul Harter
    I have an ’86 Porsche 944 with an LS1 engine swap.  The car has a full interior and essentially stock suspension.  It has 17″ Cup II wheels with DOT R tires.  From reviewing the rules, I’m guessing this car will class as Street Modified.  Does that sound right?
    Ken HammackKen Hammack
    Not an expert on classing, so maybe someone else who is will reply, but you can register in Street Modified and change your class at the event if someone says it should be a different class.
    Matt LeicesterMatt Leicester
    Two seat cars with full interiors would go into SSM, SM is four seats.  The DOT-R tires put you into SSM, everything else but on 200 TW tires would put you into XSA assuming the finished weight is over 2750 pounds, XSB if 2100 to 2749 pounds.
    Thanks for the info, Matt.  The 944 does have a backseat, so I might consider staying with TW200 tires to stay out of SSM. I’ll check the weight.
