Welcome to Rocky Mountain Solo FORUMS Event Details June 13 – 2021 Championship Series #4 (CASP)
Viewing 15 posts - 1 through 15 (of 15 total)
  • Ann CriquiAnn Criqui
    Karl TronnesKarl Tronnes
    I’ll do setup.  Karl Tronnes – 82 STR
    Kirk DunlapKirk Dunlap
    Set up please. Kirk Dunlap 144 DS
    Dan McInnisDan McInnis
    Setup please – Dan McInnis 71 AS
    Set Up:
    1) Dan Mcinnis
    2) Kirk Dunlap
    3) Karl Tronnes
    4) Brian K.
    5) Ian F.
    Tear Down:
    1)
    Ben JollyBen Jolly
    Shadow safety steward again if possible, otherwise where needed.
    Brian KillourhyBrian Killourhy
    Set up please.
    Brian Killourhy
    87 STU
    Ben, Should be able too!
    Mike DunettsMike Dunetts
    Safety Steward if possible, else wherever needed.  Thx!  Mike
    Course MapMap
    Available SSS for Sunday, I’ll assign individuals to specific heats once the run order is posted.
    Jeff Humphrey 16 CAMC
    Mike Dunetts 54 CAMC
    Hap Schadler 65 CAMT
    Aaron Botnick 42 AS
    Randy Hickman 53 AS
    Roger Mauro 33 CS
    Terrence Quinn 3 STH
    Tom Johnston 56 STS
    Bill DiGuiseppi 156 STS
    Ben Jolly Shadow
    Thanks,
    Tom
    Run/Work Order
    Run 1/Work 2
    SS BS SSC STH STR STU X W CAMS XA XB
    Run 2/Work 3
    AS DS ES FS GS HS PM
    Run 3/Work 1
    CS STS STX S CAMC CAMT
    Supervisor: Michael Mai
    Radio: Missy Tarantino
    Computer: Andrea Mai
    Log: Mark Steichen
    Scanner: David Gladu
    Supervisor: Glen Outcalt
    Radio: Salil Sukla
    Computer: Kelly Gladu
    Log: Jamie Khublal
    Scanner: Sara Sugrue
    Audit: Keith Papulski
    Supervisor: Kristina Clark
    Radio: James Darden
    Computer: Danielle Sheehan
    Log: Jeannette Wicks
    Scanner: Liza Slavin
    Audit:
    Final Audit: Melanie Dorsey
    Work assignment for SSS on Sunday.  Due to the run order some people will be working a different heat than normally.
    Work Heat 1
    Mike Dunetts 65 CAMC
    Work Heat 2
    Roger Mauro 33 CS
    Ben Jolly (Shadow)
    Work Heat 3
    Randy Hickman 53 AS
    Aaron Botnick 42 AS
    Thanks,
    Tom
    Chris GladuChris Gladu
    Tech:
    Early Tech:
    Chris Gladu
    Mike James
    During 1st heat:
    Cassidy Canadian
    Matt Villescas
    During 2nd heat:
    Mike Forsythe
    Monique Forsythe
