Welcome to Rocky Mountain Solo FORUMS Event Details July 9 – Championship Series #7 (PPIR)
Viewing 15 posts - 1 through 15 (of 18 total)
  • Jeannette WicksJeannette Wicks
    Specialty Workers
    Early Gate: 6:30-8:00: Mike James
    Second Early Gate: 8:00-9:30: Mike Bice
    Setup:
    1) Terry Brown CAMT
    2) Wayne Mohler CAMS
    3) Gillian Griffiths STR
    4) Bud Smith M
    5) Channing Williams SS
    Tear Down:
    1) Brandon Johnson DS
    2)  David Fauth X
    3) Zach Fauth STX
    Wayne MohlerWayne Mohler
    Wayne Mohler Setup please😁 CAMS #7
    Gillian GriffithsGillian Griffiths
    Could I work Setup please? 🙂 Gillian Griffiths STR 3
    John CollinsJohn Collins
    Hi Jeannette
    Trailer, Audit, Grid Captain.  Pick what you need.
    John Collins 35 STH
    Thanks John!  Requests are noted!!
    Jeffrey TattershallJeffrey Tattershall
    Course map for this Sunday
    Channing WilliamsChanning Williams
    Request to be put on course set-up
    Channing Williams – SS87
    Brandon JohnsonBrandon Johnson
    Can I please be put on course teardown
    Brandon Johnson – DS 15
    Mike DunettsMike Dunetts
    Safety please!  If not, grid assist.  Thanks! Mike
    I have you down for setup Channing!
    I have you down for teardown Brandon
    Requests noted! Thanks Mike!
    John VictoriaJohn Victoria
    Available Safety Stewards for Sunday July 9.
    Jeff Hugo
    John Bonvouloir
    Mike Dunette
    Hap Schadler
    Randy Hickman
    Jeff Humphrey
    Glen OutcaltGlen Outcalt
    Event #7 7/9/2023
    Run/Work order, Timing, SSS work assignments
    Run 1 / Work 2
    AS ES HS STX STR STU S CAMT CAMS XB
    Run 2 / Work 3
    CS DS SSC HCS X P CAMC XA
    Run 3/ Work 1
    SS BS FS GS STH STS SST W M HCR
    Supervisor:
    Radio: Salil Shukla
    Computer: Matthew Villescas
    Log: John Collins
    Announcer:
    Scanner: Robert Scourfield-Thomas
    SSS: Randy Hickman
    Jeff Humphrey
    Supervisor: Glen Outcalt
    Radio: Mark Melchior
    Computer: John Fuestal
    Log: Kelly Ann Gladu
    Audit: Charles Ervin
    Announcer: Van Townsend
    Scanner:
    SSS: Hap Schadler
    John Bonvouloir
    Supervisor: Michael Mai
    Radio: James Godlewski
    Computer: Jaime Khublal
    Log: Robert Busse
    Audit:
    Announcer: Kamen Guentchev
    Scanner:
    SSS: Jeff Hugo
    Mike Dunetts
    Final Audit: Keegan Mai
    David FauthDavid Fauth
    Teardown for David and Zach Fauth, please.
