Welcome to Rocky Mountain Solo FORUMS Marketplace E36 Dinan Supercharger Kit
Viewing 3 posts - 1 through 3 (of 3 total)
  • Scott MahalaScott Mahala
    E36 Obd1 Dinan Supercharger Kit
    -Vortech V2 S-Trim Supercharger. Rebuilt around 5000 miles ago.
    -Dinan SC bracket and belt tensioner
    -Dinan D315-0545 Crank Pulley and D315-0306 SC Pulley. 6.5psi Boost
    -All new SS hardware
    -Dinan charge pipes and intake piping w/ new stainless t-bolt clamps.
    -Dinan Bypass valve
    -Replaced Dinan open element air filter with a 4″ Spectre inline airbox.
    -Vanos banjo bolt with oil feed line for SC
    -Dinan oil dipstick tube with SC oil return
    -Dinan/Lucas D1720BA Fuel Injectors
    -413 Silver Label ECU with EWS.
    -Gates Fleet Duty SC belt
    I used a MS3 Pro plug and play for fuel management which is also for sale. If you would like to use the 413 ECU with Dinan chip you will have to have the EWS programmed with your factory key.
    Asking $2200
    • This topic was modified 6 years, 2 months ago by Scott MahalaScott Mahala. Reason: Edit Pictures
    Art HoganArt Hogan
    Is this available? Any flexibility in the price?
    Sorry the kit has been sold
