Welcome to Rocky Mountain Solo FORUMS Event Details Apr 23 – Championship Series #1 (PPIR)
Viewing 15 posts - 1 through 15 (of 15 total)
  • Ann CriquiAnn Criqui
    Please post event details, including SSS, grid sheets, maps, run/work order, and all other details concerning SS#8 within a reply to this topic. See the AVA sample topic and its replies for reference.
    Course Map
    Jeannette WicksJeannette Wicks
    SS1 Specialty Jobs
    Early Gate (7:30-9:00): Mike James
    Second Early Gate (9:00-10:30)
    Setup:
    1) Ryan Oettinger 37 CAMC
    2) Terry Brown 91 CAMT
    3) Brian Kelly 66 XA
    4) Mike Jankowski 61 HCS
    5) Jon Doran 50 CAMC
    Tear Down:  Sam Sheehan
    1) David Fauth
    2) Zach Fauth
    Ryan OettingerRyan Oettinger
    Ryan Oettinger 37 CAMC for setup please
    Jeff HumphreyJeff Humphrey
    Available SSS
    Tom Johnston – S
    John Bonvouloir – S
    Hap Schadler – CAMT
    Randy Hickman – AS
    Jeff Hugo – X
    Terrence Quinn – GS
    Aaron Botnick – AS
    Bud SmithBud Smith
    Jeanette, Because of the weather I won’t be there for set up this Sunday. Sorry for the late notice. Bud
    Jon DoranJon Doran
    Jeanette, I will take that Set Up duty if it is available with Bud having to opt out. Dibs!
    Glen OutcaltGlen Outcalt
    Event #1 4/23/2023
    Run/Work order, Timing, SSS work assignments
    Run 1 / Work 2
    AS BS CS DS HS SST SSC
    Run 2 / Work 3
    SS HCS STH STS STX STR STU W S P M
    Run 3/ Work 1
    ES FS GS X CAMC CAMT CAMS XA XB
    Supervisor: Glen Outcalt
    Radio: Keith Papulski
    Computer: Michael Mai
    Log: Andrea Mai
    Announcer: Jesse Shapiro
    Scanner:
    SSS: Hap Schadler
    Terrence Quinn
    Supervisor: Dani Sheehan
    Radio: Jaime Khublal
    Computer: Nick Chimento
    Log: BJ Fulton
    Audit: Matthew Hendel
    Announcer: Van Townsend
    Scanner:
    SSS: Aaron Botnick
    Randy Hickman
    Supervisor: Jon Kuo
    Radio: John Feustel
    Computer: Kelly Ann Gladu
    Log: Fabian Castanon
    Announcer:
    Scanner:
    SSS: Tom Johnston
    John Bonvouloir
    Final Audit:
    Robert StanleyRobert Stanley
    GRID SHEETS!
    David FauthDavid Fauth
    Teardown for David and Zach Fauth, please.
    We are going to run a delayed start tomorrow for the cold weather. Setup will start at 7:30-9 then all hands at 10 and first car off at 10:30. The temperature is supposed to warm up by then.
    If anything else changes we will update you on Facebook and on the forums.
    I’ve got you both for teardown. Thank you!
    I’ve got you down for setup.  Thanks!
    Message received!  Thanks Bud!
    Final post on times tomorrow. Registration 8-10 am. Novice walk at 9:15-9:30 just listen for announcement on speaker. Drivers meeting is at 10:30 and first car off at 10:45-11. Glen Outcalt will make the decision to switch to 2 heats later tonight or stick with 3. If you are not coming please let us know so we can change the heats if needed.
    Setup also starts at 8.
    Check in closes right at 10 though so please don’t be late.
