Welcome to Rocky Mountain Solo FORUMS Marketplace 1980 VW Pickup with 16v motorswap
Viewing 3 posts - 1 through 3 (of 3 total)
  • mason thomasmason thomas
    1980 VW Rabbit Pickup
    $2500 – OBO
    Body:
    Less than 100k on rust free shell
    ’88-93 Cabriolet front end conversion (4 round headlight)
    Cabriolet European front bumper
    Front fender flares modified to match
    Smoked euro side maker lights and turn signals
    Replaced all rubber and window seals
    Line-X bed liner
    Polished aluminum bed rails
    Armor door guards
    Motor: European Corrado 2.0L 16v w/European intake cam(less than 25k on motor)
    16v Scirocco Fuel Injection System
    Polished intake manifold
    Throttle enrichment module
    Schrick aluminum oil pan
    Techtonics Dual outlet downpipe, w custom techtonics midpipe to exhaust
    Upgraded A/C 16v system
    Upgraded P/S 16v system
    5 speed 16v close ratio transmission
    16v Scirocco front wheel housing w/ 100mm CV axles
    Neuspeed short shift kit
    Interior:’88-93 Cabriolet Dash w/ gauge console
    Oil pressure / Voltage / Oil temp
    ’81-84 Jetta lower partial shelf
    Jetta door cards
    Cabriolet carpet
    ’90-92 Jetta Recaro seats w/ power adjustment
    Alpine alarm system with power door locks
    Pioneer Head unit
    Brakes and Chassis:
    16v Scirocco brake master cylinder and booster
    10.1” Neuspeed cross drilled rotors w/ stainless steel brake lines
    Brake portioning valve
    Upgraded larger rear drums
    15” Konig Helium Wheels
    Neuspeed upper strut tie bar
    16v Scirocco front lower “K” stress bar
    Upgraded KYB front struts with lowering springs
    OEM Sachs rear shocks
    The not so good:
    Drivers side damage to the front fender and door
    Paint clear coat has seen better days
    Needs a new battery
    Tires need to be replaced
    josh wytejosh wyte
    I’m interested in the caddy, can you send me more pics?  docwyte at comcast dot net.  Thanks!
    Messaged you
