Welcome to Rocky Mountain Solo FORUMS Event Details ❄ March 26 – Winter Series #6 (PPIR) ❄
Viewing 15 posts - 1 through 15 (of 15 total)
  • Ann CriquiAnn Criqui
    Specialty Jobs:
    Early Gate: 7:30-9:00
    Second Early Gate: 8:30-10
    Set Up:
    1) Mick
    2) Reuben Brown
    Tear Down:
    1) Terry Brown
    Chelsea,
    If I don’t get tagged for Safety please put me down for grid.
    Thanks,
    Tom
    Terry BrownTerry Brown
    Chelsea,
    Teardown please.
    91 CAMC
    Mick RosacciMick Rosacci
    Hi, I started Safety Steward classes last week and think the next step is being a Deputy Safety Steward. I requested course set-up at sign up and can do both; starting with setup and switch to following Safety when they get started.  Or glad to do whatever is helpful to the club.  Best!
    That works Mick! Setup then follow safety when they start! Thanks for letting me know!
    Mike DunettsMike Dunetts
    Safety is possible, else tech, else whatever!  Thx!
    Reuben BrownReuben Brown
    Ill help setup
    95 XA
    John VictoriaJohn Victoria
    Mike you can shadow one of the heats if you’re up for it, thanks you very much…
    Sorry I meant Mick not Mike.
    SSS for 3/26
    Mike Dunetts, Jeff Humphrey, Ranty Hickman, John Victoria
    Glen OutcaltGlen Outcalt
    Run 1 / Work 2
    CS DS ES GS SSC HCS STX STR CAMC CAMT CAMS XA XB
    Run 2 / Work 1
    SS AS BS FS HS STH STU X S PM
    Trailer work assignments
    Computer: Jeanette Wicks
    Radio: James Darden
    Scanner:
    Supervisor: Jonathon Kuo
    Computer: Kelley Jaeger
    Radio: Mike Trenkle
    Scanner:
    Supervisor: Glen Outcalt
    Heat 1 Safety
    Randy Hickman
    John Victoria
    Heat 2 Safety
    Mike Dunetts
    Jeff Humphrey
    Safety team, I’ll be there to set up, then I run first heat and can shadow you all in the second heat. Thanks!  Mick Rosacci
    Michael SherwinMichael Sherwin
    Who should I talk to about changing cars/class?  i am dropping out of CS and will be running SS. Thx
    Robert StanleyRobert Stanley
    Grid Sheets!!!
