Welcome to Rocky Mountain Solo FORUMS Event Details ❄ December 12 – Winter Series #3 (PPIR) ❄
Viewing 12 posts - 1 through 12 (of 12 total)
  • Ann CriquiAnn Criqui
    Post event details here for Winter Series #3.
    Specialty Jobs:
    Early Gate: 7:30-9
    Second Early Gate: 8:30- 10
    Set Up:
    1) Joe Brennan
    2) Mike Cahill
    3) Reuben Brown
    4) Jon Doran
    Tear Down:
    1) Brandon Meadows
    Joe BrennanJoe Brennan
    I’ll take a setup spot please.
    Joe Brennan. XB 23
    Thanks!
    Mike CahillMike Cahill
    Setup Please
    Mike Cahill
    40CAMC
    Reuben BrownReuben Brown
    It’s my first time attending, but I will help set up
    Reuben Brown    44 STH
    Glen,
    SSS for Sunday will be:
    Tom Johnston 56CAMC
    Jeff Hugo 2STX
    Based on this CAMC and STX will need to run different heats.  If Jeff Hugo isn’t able to come the backup is Jeff Humphrey who is also in CAMC, 16 CAMC, so I’ll need to run the opposite heat from CAMC so we have a SSS for each heat.
    Thanks,
    Tom
    Jon DoranJon Doran
    Jon Doran CAMC50  for set up as well?
    Glen OutcaltGlen Outcalt
    Run/Work Order
    Run 1/Work 2
    SS FS GS STH STR CAMC CAMS XB
    Run 2/Work 1
    AS CS DS ES HS STX STU OST S PM CAMT XA
    Timing and scoring work assignments.
    Supervisor: Glen Outcalt
    Radio: Hsun Chen
    Computer: John Feustal
    Log: Keith Papulski
    Scanner:
    Supervisor:
    Radio: Mike Trenkle
    Computer: Kelley Jaeger
    Log: Jeanette Wicks
    Scanner:
    Robert StanleyRobert Stanley
    Grid Sheets!!!
    SSS for Sunday
    Work heat 1
    Jeff Hugo 2STX
    Work heat 2
    Tom Johnston 56CAMC
    Brandon MeadowsBrandon Meadows
    I’ll take a tear down spot, please.
    Brandon Meadows, CS #91.
    Thank you!
