Welcome to Rocky Mountain Solo FORUMS Marketplace Miata Parts (free)
Viewing 3 posts - 1 through 3 (of 3 total)
  • Graeme DGraeme D
    Free to a good home, (but if you twist my arm, I’ll take beer)
    This stuff is off a 1994 1.8L Miata
    NA engine under tray with grill insert
    Complete cylinder head 1.8L, 110K miles, ran great when removed (replaced with a 2001 head)
    Intake manifold
    Exhaust Manifold and mid pipe
    ignition coils & plug wires
    crank angle sensor (CAS)
    throttle body w/TPS (no ICV)
    MAF sensor
    complete air-box & crossover tube
    charcoal canister & purge control valve
    used pistons, stock size, 110k miles
    front control arms and uprights
    94 ABS system
    94 master cylinder and booster
    NA 1.8 front brake calipers
    ’94 power mirrors with all wiring
    lots of small bits
    2001 VTCS intake manifold
    ‘99 steering rack with a welded the pinion shaft (de-powered).
    ’01 rear sport calipers
    ’99 power steering pump
    hard top latches
    oem seals that will fit aftermarket hard top
    Bring a truck,
    Located between Arvada & Golden, Near I-70
    we can maintain good social distancing throughout the process!
    reply with a post & PM
    • This topic was modified 5 years ago by Graeme DGraeme D. Reason: add photo
    You must be logged in to view attached files.
    Graeme DGraeme D
    Forgot to say,
    All or nothing, I don’t want to waste time with piece meal parts.
    • This reply was modified 5 years ago by Graeme DGraeme D.
    Graeme DGraeme D
    All parts are gone
