1980 VW Rabbit Pickup
$2500 – OBO
Body:
Less than 100k on rust free shell
’88-93 Cabriolet front end conversion (4 round headlight)
Cabriolet European front bumper
Front fender flares modified to match
Smoked euro side maker lights and turn signals
Replaced all rubber and window seals
Line-X bed liner
Polished aluminum bed rails
Armor door guards
Motor: European Corrado 2.0L 16v w/European intake cam(less than 25k on motor)
16v Scirocco Fuel Injection System
Polished intake manifold
Throttle enrichment module
Schrick aluminum oil pan
Techtonics Dual outlet downpipe, w custom techtonics midpipe to exhaust
Upgraded A/C 16v system
Upgraded P/S 16v system
5 speed 16v close ratio transmission
16v Scirocco front wheel housing w/ 100mm CV axles
Neuspeed short shift kit
Interior:’88-93 Cabriolet Dash w/ gauge console
Oil pressure / Voltage / Oil temp
’81-84 Jetta lower partial shelf
Jetta door cards
Cabriolet carpet
’90-92 Jetta Recaro seats w/ power adjustment
Alpine alarm system with power door locks
Pioneer Head unit
Brakes and Chassis:
16v Scirocco brake master cylinder and booster
10.1” Neuspeed cross drilled rotors w/ stainless steel brake lines
Brake portioning valve
Upgraded larger rear drums
15” Konig Helium Wheels
Neuspeed upper strut tie bar
16v Scirocco front lower “K” stress bar
Upgraded KYB front struts with lowering springs
OEM Sachs rear shocks
The not so good:
Drivers side damage to the front fender and door
Paint clear coat has seen better days
Needs a new battery
Tires need to be replaced
